Trane Xv80 Dead With A Blinking Light - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2014, 12:25 AM   #1
trane xv80 dead with a blinking light
I have a 11 year old trane xv80 heat and air unit. I know the warranty ended at 10 years.
The problem - when i turn on the heat using the white rogers thermostat i get nothing. no blower, no heat, no clicks just a blinking light on the board.
The vent fan - nothing comes on. The circuit board was replaced with a update three years ago and has worked fine. The temp is 4 degrees outside and this happens.
I turned the power off to the furnace and back on twice thinking it would reset. I just get a steady blinking light nothing else clicks or hums.
Is there a troubling shooting list or blinking light test?
sheltie is offline   Reply With Quote
Old 01-06-2014, 12:27 AM   #2
The blinking light is on the circuit board- just steady slow blinking.
Old 01-06-2014, 04:09 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Jumper R to W at the thermostat and if that does not work then jumper R to W at the furnace control board. This is essentially bypassing the thermostat.
Slow flash is normal operation: no call for heat present
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-06-2014, 05:20 AM   #4
fixed
Thanks,
The red power wire and the wire next to it were cut or broken. I cut them all back and reinserted them on the board. Turned the power back on and the system fired up. Both wires were cut off at the insulation and i hadn't noticed until you mentioned the bypass. Very strange.
The temp is going down to 4 and now the heat works, Thank you
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
HELP! Trane XV90 Solid Red & Green Light consultant HVAC 1 10-27-2011 04:00 PM
Trane XE90 control board dead? phatsupratt HVAC 4 09-24-2011 06:30 PM
Blinking low voltage light nickdu Electrical 11 11-09-2009 09:09 PM
Closet Light Went Dead kennelm Electrical 9 07-25-2006 06:19 AM
