Trane XV-80 No Worky - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 09:55 PM   #16
it isn't that it's flashing 7 times..... it flashing very fast for about seven seconds, then goes out for 2, then repeat. like its telling me something, but I don't have the diag codes for the green led, if there are any.
ed van is offline   Reply With Quote
Old 01-10-2009, 10:00 PM   #17
JohnH1's Avatar
Thats not a code. There are no codes on the CFM led. Were you able to check if there was power across Y and B or remove the Y & Ylo wires to see what happened.
JohnH1 is offline   Reply With Quote
Old 01-11-2009, 11:10 AM   #18
No power across y and b during call for heat.
Here's something I noticed. If I turn the fan on manually to on, turn on the heat, it seems to work fine. CFm flashing 10 time, 1000 cfm right? well, as soon as it goes to second stage heat and tries to spin up blower, it does for about 15 seconds, CFm flashing 12 times....then it shuts off the blower.
Should I disconnect w2 on thermostat and see if it will run with just w1 connected?
Old 01-11-2009, 11:15 AM   #19
JohnH1's Avatar
Sure to get some heat going untill it is figured out. This is a new one to me.
Old 01-11-2009, 12:41 PM   #20
I pulled w2, it ran for awhile, then stopped.
Old 01-11-2009, 12:48 PM   #21
JohnH1's Avatar
Since the fan operates by itself with no problem and the problems only arise when there is a call for heat I would have to still assume it is still the board. Are the led's still lit on Y and Ylo and do the stay lit if you remove the wires from the termonals?
Old 01-12-2009, 03:28 PM   #22
Y and YLo are not lit. They looked like they were lit dimly, but they weren't. I should be getting new board today.
Old 01-12-2009, 10:45 PM   #23
Talking
heat blowing strong. bad board. Thanks for all the info and suggestions.
Old 01-13-2009, 12:18 PM   #24
JohnH1's Avatar
Thanks for letting us know it is always nice to here about the final outcome.
Help TRANE XE-80 furnace squeed HVAC 14 12-31-2014 11:29 PM
Are Trane heat pumps and Am Std exactly the same? jgtaylorjr HVAC 1 06-01-2008 09:35 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 12:16 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
