Trane XR95 - Want To Wire A Manual Blower Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 03:38 PM   #1
Rewards Points: 160
Trane XR95 - want to wire a manual blower switch
I never knew new furances wouldn't come with a "summer fan"...pretty dumb!
I don't need A/C here but want to circulate the cool air around by running the fan only.
Here is the 2 ways i have found so far on the net
1) Run jumper from R to G in the furnace and run it to a switch, then somehow wire this to the G on your thermostat
2) use 18/5 wire and get a Honeywell Vision Pro 8000 that has a "Circ" option
Now I don't think it can be that hard, just need to know where I can find some info so i can wire it to my thermostat. I talked to my furnace installer who said it doesn't come with a summer fan and that an electrician can wire in a new thermostat if you want...I asked would an electrician know how to wire it and they said "he should..."
Nice!
hellothere123 is offline   Reply With Quote
Old 06-12-2011, 03:52 PM   #2
An old Tradesmen
Rewards Points: 6,130
Just run a 18/3 or better(if you want to use a thermostat that isn't battery powered) wire to your current thermostat location, and use any thermostat that has A/C control also. Then just turn the fan switch to "on". Need to have RH/RC jumpered in the stat, and connect stat W to W in furnace and stat G to G in furnace. Along with C to C if you use a stat that is not battery powered.
Old 06-12-2011, 05:56 PM   #3
Rewards Points: 160
Thanks for replying, wold you be able to walk a total rookie through this?
Right now I have a thermostat that is battery operated, so are you saying to jumper RH/RC in the stat, then jumper W to W and G to G in the furnace?
what wire connects the stat to the furnace jumpers?
If you could walk me through it, I know it can be frustrating, but I don't want to do it wrong and then fry the board on the furnace...
Old 06-12-2011, 11:25 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
wire G in furnace to G in stat and jumper RC to RH in stat if not already jumpered. The fan control will now function from the stat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Blower fan won't turn off - limit switch replaced Laplacian HVAC 4 02-14-2011 12:55 PM
Red Wire Travler and Switch Operation ferrerij Electrical 3 03-14-2010 11:48 PM
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
