Trane XR95 - How To Adjust Fan Speed? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 07:36 PM   #1
Trane XR95 - how to adjust fan speed?
Hi guys,
I had a new furnace installed (Trane XR95 - TUH1B080A9421A - single stage furnace) for my home. I find the fan quite loud and would like to lower the setting if possible (it has 4 settings). I look through the manual but am confused. Could any explain how I can achieve this?
Thanks.
Steve19 is offline   Reply With Quote
Old 09-16-2011, 09:54 PM   #2
Rewards Points: 494
Another common place with a schematic is on the back of the blower fan door. Most require that you open a box (2 screws?) with a wiring harness for the fan. 3 of the wires will likely terminate with just a twist on cap. But the 'real' one will be the one connected with a twist on cap to the fan motor.
If the schematic is on the door, note the color coding of wires and then swap, in your case, to a lower speed. Most high is usually for A/C.
diyorpay is offline   Reply With Quote
Old 09-17-2011, 08:16 AM   #3
Rewards Points: 161
If you lower the blower speed make sure you check the temperature rise across the heat exchanger or you may damage it. There should be a specification decal on the inside of the furnace adjacent to the gas valve. This will tell you the maximum temperature rise for your unit.
kb3ca is offline   Reply With Quote
Old 09-17-2011, 05:10 PM   #4
An old Tradesmen
Rewards Points: 6,914
Before lowering your fan speed. Check the temp rise across the heat exchanger. if its high already. then lowering the blower speed may increase it above a safe level for the heat exchanger. And cause you lots of no heat problems. Or burn out your heat exchanger.
Trane XR95 Problems cipherman HVAC 10 12-04-2014 07:49 PM
variable speed trane blower motor afn63537 HVAC 25 01-13-2013 05:31 PM
Trane 1HP motor speed controller dejswa HVAC 6 07-26-2010 11:18 AM
How to adjust blower speed? chrism7 HVAC 13 08-24-2009 12:14 PM
Trane XV80 - low speed fan not working oregondean HVAC 4 01-12-2009 12:46 PM
