Old 10-10-2012, 04:24 PM   #31
An old Tradesmen
Trane XR90 Pressure Switch Error
If you have a hose blanked off to the pressure switch to run your furnace. Then most likely, there is something unsafe with your furnace.
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Pressure Switch Stuck Closed --heat works but A/C doesnt assassinmunky HVAC 0 06-23-2009 03:49 PM
Comfortmaker C9MPD100J14C Only goes on when I unplug and Replug pressure switch wire? kevin211mvd HVAC 7 11-15-2008 11:58 PM
PAYNE Pressure switch error code 23 WRKPA HVAC 1 02-04-2006 07:37 AM
What engages pressure switch? dfferg HVAC 1 09-12-2005 11:27 PM
