Trane Xr90 Leaking Water From Behind Inducer! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-30-2013, 11:56 PM   #16
Thanks hvactech126. You rule!
njohns is offline   Reply With Quote
Old 12-01-2013, 05:17 AM   #17
An old Tradesmen
Rewards Points: 8,154
Originally Posted by njohns View Post
I tried to look through the small rectangular hole behind the transition receptacle but didn't have much luck.... my inspection mirror is too large.
Anyway, what makes you think the collector box could be cracked? The only evidence of leaking water is clearly from the front screw hole of the transition receptacle.
Thanks.
Its a known problem. I usually find 2 or 3 a year.
The Following User Says Thank You to beenthere For This Useful Post:
njohns (12-01-2013)
Old 12-01-2013, 08:06 AM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 382
RTV silicone is what Pros use. available at auto stores.
The Following User Says Thank You to yuri For This Useful Post:
njohns (12-01-2013)
Water in inducer, furnace short cycling joe citizen HVAC 3 11-25-2013 01:08 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Main hot water pipe leaking under slab tiredofleaks Plumbing 9 09-12-2011 02:45 PM
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 08:29 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
