Trane Xr90 Leaking Water From Behind Inducer! - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2013, 01:04 PM   #1
Trane xr90 leaking water from behind inducer!
Noticed water dripping down onto control board. Removed inducer and found water seems to be collecting in black plastic "tray" between inducer and combustion unit (see attached photos).
But it does not seem like water should collect in that tray as there is no where for it to go, so what could be the root cause???
Thanks!
Trane xr90 leaking water from behind inducer!-012.jpg   Trane xr90 leaking water from behind inducer!-013.jpg   Trane xr90 leaking water from behind inducer!-017.jpg
njohns is offline   Reply With Quote
Old 11-30-2013, 04:21 PM   #2
An old Tradesmen
Rewards Points: 7,414
Thee is a rectangular plastic piece behind that panel yet. Its probably cracked. Also a good chance the plastic collector box behind it is cracked. If so, heat exchanger needs to be replaced.
Old 11-30-2013, 04:48 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
The inducer installs to the inducer receptacle. I have only ever found that part at a supply house and not on the internet.... good luck
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-30-2013, 07:13 PM   #4
Thanks for the reply. By "rectangular plastic piece" do you mean the part shown from the side in the photo below? Is this what Hvactech126 is referring to as the "inducer receptacle"?
This part does not seem to be cracked. Rather, the water just seems to be leaking out around the screw on the left (as viewed from the front) because there is nowhere else for it to go. That plastic piece does not look like it is designed to have water accumulate in it as it has no drain.
Water accumulating in the inducer or exhaust should drain out of the bottom inducer housing, right? But could water be dripping in front of the inducer fan opening inside the ex changer and getting sucked in by the inducer? What would cause that?
Thanks again!
Old 11-30-2013, 07:26 PM   #5
AKA HVACTECHFW
The screw hole is cracked... remove the metal in front of the receptacle and you will see...
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
njohns (11-30-2013)
Old 11-30-2013, 08:20 PM   #6
You were absolutely correct hvactech126! It was badly cracked around the screw and in other places (see attached pics).
I found service bulletin FURN-SVB22A-EN (http://www.desertmountaintrane.com/t...%2010-2006.pdf) which suggests that this was a design weakness with the part (Transition Receptacle RCT00084).
Googling that part I am actually able to find several sources online, but I think I also should replace the metal plate that goes in front of it as it is rusted almost completely away around that screw hole. Any idea of that part number???
Thanks again!
Trane xr90 leaking water from behind inducer!-018.jpg   Trane xr90 leaking water from behind inducer!-020.jpg   Trane xr90 leaking water from behind inducer!-025.jpg   Trane xr90 leaking water from behind inducer!-023.jpg
Old 11-30-2013, 08:46 PM   #7
AKA HVACTECHFW
Give me a model number of your furnace and I can look it up
IT IS WHAT IT IS
Old 11-30-2013, 09:01 PM   #8
Model TUX100C960D1
Serial 30432WM7G
Thanks!
Old 11-30-2013, 09:11 PM   #9
An old Tradesmen
Examine the collector box to make sure its not cracked.
Old 11-30-2013, 10:28 PM   #10
AKA HVACTECHFW
Originally Posted by njohns View Post
Model TUX100C960D1
Serial 30432WM7G
Thanks!
Looks like my former employer finally disabled my comfortsite access.... sorry, I can no longer look that information up for you
IT IS WHAT IT IS
Old 11-30-2013, 10:50 PM   #11
Thanks for trying. You've been a big help in any case!
Old 11-30-2013, 11:40 PM   #12
I tried to look through the small rectangular hole behind the transition receptacle but didn't have much luck.... my inspection mirror is too large.
Anyway, what makes you think the collector box could be cracked? The only evidence of leaking water is clearly from the front screw hole of the transition receptacle.
Thanks.
Old 11-30-2013, 11:48 PM   #13
AKA HVACTECHFW
Thanks.
It is a known problem on some furnaces.... I have only seen 2 do it.
IT IS WHAT IT IS
Old 11-30-2013, 11:52 PM   #14
I was able to find it by searching on a parts supplier site using my model number. It is MNT01266 (Motor Mount Plate). This and the transition receptacle will be only about $40 delivered.
For now I've epoxied up the cracked one and re-installed to heat the house until I get the parts.
One more question: Any particular sealant I should use at the two openings of the transition receptacle. It looked like some sort of silver silicone was on there previously...
Thanks a bunch!
Old 11-30-2013, 11:54 PM   #15
AKA HVACTECHFW
high temp silicone
IT IS WHAT IT IS
njohns (11-30-2013)
Water in inducer, furnace short cycling joe citizen HVAC 3 11-25-2013 01:08 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Main hot water pipe leaking under slab tiredofleaks Plumbing 9 09-12-2011 02:45 PM
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 08:29 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
