Old 11-15-2011, 07:38 PM   #31
Trane XR90 - 3 Red Lights
Originally Posted by Tom Scott View Post
He's confussed. Tested it with a new pressure switch and he gets the same thing. Hes calling his boss now.
should of asked for the older more experienced guy.......
harleyrider is offline   Reply With Quote
Old 11-15-2011, 07:43 PM   #32
Originally Posted by beenthere View Post
Clogged/restricted pressure hose. Restricted exhaust or combustion air intake pipe. Corrosion build up on hose pressure ports. Restricted drain line. Crack in a pressure hose. Slow spinning inducer. Cracked heat exchanger. loose restricter plate on the back of the inducer.
The tech should use a manometer and see how much pressure the switch is seeing.
He has a fancy meter hooked up to the burner box now where the hose to the switch usually runs - I thinks hes testing the pressure.
Tom Scott is offline   Reply With Quote
Old 11-15-2011, 07:49 PM   #33
meter shows negative pressure out of the burner box.
Old 11-15-2011, 07:50 PM   #34
He said the meter shows negative pressure out of the burner box.
But he admits hes confussed and frustrated.
Now he is taking off the intake pipe that is above the burner box....
ta-da!!!!!
Old 11-15-2011, 07:56 PM   #35
It runs with the burner box open and the pressure swtich hoses hooked up properly.
Looking like an intake problem maybe, he thinks there might be a blockage.
Old 11-15-2011, 07:59 PM   #36
I asked for an expierenced guy and told them I would call a different comapny if they did not know ho to service this model.
Old 11-15-2011, 08:00 PM   #37
post #22
Old 11-15-2011, 08:01 PM   #38
An old Tradesmen
Is it making a gurgling sound when its burning?
Old 11-15-2011, 08:02 PM   #39
not that I hear
Old 11-15-2011, 08:06 PM   #40
I asked for an expierenced guy, this is what they sent me
the good thing is he is getting valuable experence...........on your dime
Old 11-15-2011, 08:09 PM   #41
we tallked earlier about the trap......have him clean it while he is there.....
Old 11-15-2011, 08:13 PM   #42
lol - thanks that makes me feel so much better.
Old 11-15-2011, 09:38 PM   #43
Well Tom, whats the verdict?
Old 11-15-2011, 09:44 PM   #44
Update
He left and I am right back where I started.
He wants to come back tomorrow after he talks to the manufacturer and get their advice.
Another guy came over and they both checked everything they thought might be the cause but found nothing but maybe something is in the intake pipe.
He wants to come back tomorrow and cut the intake pipe to look into it to see if its blocked.
The other guy read thru the install manual and said there is too many bends in the pipe that make the overall pipe length 10 feet too long based on the install manual and maybe that’s the problem.
They also said the inducer motor is at .5 something and the book said it should be .7
Right now they left it running with the burner box open just a crack and the hoses hooked up to the pressure switch because it runs that way with no error.
So that’s it for now.
Old 11-15-2011, 09:46 PM   #45
tom send me a private message............i want to give you my cell so you can call me
Trane XR90, LED flashes 2 times for error James35 HVAC 48 12-16-2012 12:49 PM
Trane XR90 Pressure Switch Error kenk HVAC 30 10-10-2012 04:24 PM
where is the pressure switch on trane xr90 jeb 1029 HVAC Site - PROS ONLY 0 10-16-2011 07:25 PM
Trane XR90 four flashes question dkgreen HVAC 1 11-24-2010 06:03 AM
Trane XR90 Mike2401 HVAC 32 12-22-2009 02:18 PM
