Trane Xr90 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 07:26 PM   #1
Trane xr90
I bought and installed two years ago and have had no problems with it. Last week I turned on the heat for the first time this year everything was working well until yesterday. After the heats been off for some time and tries to fire for the first time the burners will not stay lit. It lights and will fire for about 3 to 5 seconds then shuts down. It will do this for 3 times then lock out. Iíll reset and it usually fires and stays lit on the first try. Anyone have an idea on what could be bad? I was thinking control panel.
Mike
mdnbike is offline   Reply With Quote
Old 10-23-2011, 07:40 PM   #2
Only a 3-5 second burn is almost always a flame sensor that needs cleaned.
Old 10-23-2011, 09:03 PM   #3
I cleaned it with sandpaper and it's doing it every time. It stills lit after I reset it.
Old 10-23-2011, 10:03 PM   #4
30 year tech
hvac122's Avatar
Should never clean it with sandpaper. What reading are you getting from it?
hvac122 is offline   Reply With Quote
Old 10-27-2011, 07:04 PM   #5
OK I put in a new flame sensor, works better but it will still go into lock out every now and then.
Thanks for the help
Mike
Old 10-27-2011, 08:01 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
remove and clean the burner faces. Also ensure there is a ground attached to the burner box... should be near the manifold screws on side or the other.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-29-2011, 06:25 AM   #7
How should you clean the burner faces?
1jumper is offline   Reply With Quote
Old 10-29-2011, 08:17 AM   #8
AKA HVACTECHFW
remove the burners and clean the faces with a steel brush....
IT IS WHAT IT IS
Trane XR90 Pressure Switch Error kenk HVAC 31 10-24-2015 12:16 AM
TRANE XR90 LED flashes 2 times serius HVAC 3 12-16-2010 10:43 AM
Trane XR90 four flashes question dkgreen HVAC 1 11-24-2010 05:03 AM
Trane XR90 keeps blowing fuse McTreez HVAC 1 11-01-2010 04:56 AM
