Trane XR12 Heat Pump Condenser Unit Hookup - HVAC - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 10:49 AM   #1
I am mating it to existing air handler. Just need to verify the correct reconnect wire sequence to newer unit.
Old Unit board/wire
G Green
E Black
W1 Light Tan brown
W2
W3 Red
R Yellow
Y Pink/light orange
C Blue
New Unit Wire
Orange
Blue
Yellow
Black
Red
Brown
Double Yellow with connector
Old
New
cbrf1wr is offline   Reply With Quote
Old 08-11-2013, 06:56 PM   #2
An old Tradesmen
Rewards Points: 7,400
Would need to know what the wires are coming from, on the new unit.
Old 08-11-2013, 08:15 PM   #3
Wiring Diagram
Old 08-11-2013, 09:01 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
Red (R) 24VAC hot
Blue( B/C) = 24VAC common
Orange (O)= reversing valve with cooling
Black (X2) = aux heat
Brown (T) = ODT (not used unless a Trane thermostat with a T terminal)
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat pump short-cycles (heat only) dgp1939 HVAC 5 11-01-2011 02:43 PM
trane x19i heat pump MrSnapRon HVAC 8 08-29-2009 01:17 PM
Can I use an a/c evaporator A coil with a Heat Pump condenser? fiver HVAC 26 03-22-2009 06:24 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
