Trane Xr11 Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 08:44 PM   #1
Trane xr11 heat pump
The unit keeps turning on and off every 5 minutes. It is 100 degrees outside. I've got the thermostat set at 75 degrees yet it still continues. The suction side is sweating and cold.
Distraught is offline   Reply With Quote
Old 07-11-2011, 09:00 PM   #2
What keeps turning on and off?
The air handler inside!!!
or the condenser outside???
Artco is offline   Reply With Quote
Old 07-11-2011, 09:02 PM   #3
JJboy's Avatar
Check if the condenser coil is dirty. Does AC is cooling?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-01-2011, 07:48 AM   #4
XR11 Problem
Check to see if it has the right capacitor. It is a 45/5MFD 440V Round Cylinder shape.
If you already found the problem let me know what it was.
ernie_the_dog is offline   Reply With Quote
What did I do? Heat Pump isn't working ChrisDIY HVAC 10 03-14-2011 03:55 PM
Trane Heat pump capacitor exploded! swiffy25 HVAC 18 01-19-2011 05:48 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Trane Heat Pump acting up..frozen (XR13) VEIK HVAC 1 10-20-2008 03:00 PM
