Old 10-01-2012, 01:31 AM   #1
Angry
Trane XL90 transformers
This unit has blown two transformers in the last month. Our hvac man just replaces them. There has to be another problem blowing these units. I don't know enough about this particular gas heater, and I don't feel the hvac guy is troubleshooting the unit further. Any suggestions to what is poping these transformers?
Mick Mason is offline   Reply With Quote
Old 10-01-2012, 06:53 AM   #2
Low voltage short.This time of year I'd look for mouse chewed wires in or around the AC.
The Following User Says Thank You to Marty S. For This Useful Post:
Mick Mason (10-01-2012)
Old 10-01-2012, 07:20 AM   #3
Professional
you can install an inline 3A fuse on the low voltage side to protect the transformer. Fuses are much cheaper than transformers! But yes there is a short somewhere that is the underlying cause.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-01-2012, 09:42 AM   #4
jWell the easiest solution is always best!! And a new digital thermostat couldn't hurt. Thank You!!
Originally Posted by hvactech126 View Post
you can install an inline fuse on the low voltage side to protect the transformer. Fuses are much cheaper than transformers! But yes there is a short somewhere that is the underlying cause.
Old 10-01-2012, 10:38 AM   #5
In this case new stat won't help either. Look over all the wiring and repair/replace any damaged or loose connections.
techpappy is offline   Reply With Quote
Trane XL90 heat exchanger Lizardking HVAC 2 11-01-2011 09:44 PM
Replacing Trane XL90 Vent Inducer NoSmoke HVAC 5 04-02-2010 05:14 PM
Trane XL90 slight vibration Jeff57 HVAC 1 12-14-2009 09:39 PM
Trane XL90 Annual Problems C63 HVAC 2 10-20-2008 06:01 AM
Trane xl90 Combustion blower Issues bjpaff HVAC 3 12-18-2007 11:00 PM
