Trane XL90 Heat Exchanger - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 08:33 PM   #1
Trane XL90 heat exchanger
Hi,
I was told by a tech that my five year old Trane XL 90 needed a heat exchanger. The part is under warranty but the labour would be $1000.00 (does that sound right?). I have looked at my contract and it states that the warranty covers both parts and labour. If the warranty covers parts I figure it should also cover labour, correct??
Also does it make sense that a 5 yr old furnace should be needing a heat exchanger? This is the first time that I have had to change a heat exchanger and I have had furnaces well over 20 years old?
Thank you.
Lizardking is offline   Reply With Quote
Old 11-01-2011, 08:44 PM   #2
I would call the a/c contractor and discuss the warranty with them. If the tech quoted this, he might not have known about your warranty. If you are questioning the diagnosis, ask for a senior tech to come out. Have him check the static pressure of the duct system as well as the heat exchanger.
Master of Cold is offline   Reply With Quote
Old 11-01-2011, 09:44 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
I have only ever seen 3 Trane serpentine style 90% heat exchangers fail. Make them show you the failure. Get a second opinion. Have them check your part and labor warranty.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Service tech won't repair furnace with cracked heat exchanger. GloBigRed HVAC 16 11-18-2010 03:27 AM
Trane xe80 no heat tackman HVAC 9 11-05-2010 02:33 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Are Trane heat pumps and Am Std exactly the same? jgtaylorjr HVAC 1 06-01-2008 10:35 PM
