Trane XL80 Model TUD - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 09:26 AM   #1
Trane XL80 model TUD
My 20 year old Trane XL80 model TUD stopped working. I turned it off, then back on. The upper motor starts. 15 seconds later, I hear clicking from the pressure switch, then what I believe to be gas flowing for 3-5 seconds. The upper motor continues to run for a a minute, then stops. There is no visible flame. I checked the tubing to the pressure switch. It's OK. The red light in the lower portion of the unit flashes quickly, and steadily. Help, please.
tamster19 is offline   Reply With Quote
Old 12-12-2010, 09:31 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
HSI hot surface igniter is burnt out/cracked. May want to get a Pro to change it as they are VERY delicate and tricky to install. May look like this one. There are up to 12 different variations of them.
The Following User Says Thank You to yuri For This Useful Post:
tamster19 (12-12-2010)
Old 12-12-2010, 09:47 AM   #3
Thanks!
Yuri- Is this common? Where is it located? I'm pretty handy, and short on cash...
Old 12-12-2010, 09:56 AM   #4
Hsi
Yuri- I found it. Is there any way to test it?
Old 12-12-2010, 10:02 AM   #5
Hvac Pro
yuri's Avatar
Very common. Sits in front of one of the burners. Should have between 35-70 ohms resistance on those 2 wires. Use alligator clips from the meter leads to the wires or the meter will read your body resistance. Usually it has a bright white spot where it burnt out. If higher than 70 or O.L.( open line) then it is shot.
Old 12-12-2010, 12:12 PM   #6
If you take the task to replace it try not to touch with fingers oil from hand can cause hot spots latex gloves will help very easy to break
Hixheat1 is offline   Reply With Quote
Tags
trane , tud , xl80
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Trane XL80 Heat won't come on roma24 HVAC 1 12-31-2009 10:18 AM
Trane XL80 ignitor won't glow mikerodg HVAC 2 12-11-2009 03:34 PM
Trane Carrier XL80 fan runs constantly when switch is on jheavner HVAC 13 10-25-2008 09:54 PM
