-   -   Trane XL80 model TUD (http://www.diychatroom.com/f17/trane-xl80-model-tud-89387/)
tamster19 12-12-2010 10:26 AM
My 20 year old Trane XL80 model TUD stopped working. I turned it off, then back on. The upper motor starts. 15 seconds later, I hear clicking from the pressure switch, then what I believe to be gas flowing for 3-5 seconds. The upper motor continues to run for a a minute, then stops. There is no visible flame. I checked the tubing to the pressure switch. It's OK. The red light in the lower portion of the unit flashes quickly, and steadily. Help, please.
yuri 12-12-2010 10:31 AM
1 Attachment(s)
HSI hot surface igniter is burnt out/cracked. May want to get a Pro to change it as they are VERY delicate and tricky to install. May look like this one. There are up to 12 different variations of them.
tamster19 12-12-2010 10:47 AM
Thanks!
Yuri- Is this common? Where is it located? I'm pretty handy, and short on cash...
tamster19 12-12-2010 10:56 AM
Hsi
Yuri- I found it. Is there any way to test it?
yuri 12-12-2010 11:02 AM
Very common. Sits in front of one of the burners. Should have between 35-70 ohms resistance on those 2 wires. Use alligator clips from the meter leads to the wires or the meter will read your body resistance. Usually it has a bright white spot where it burnt out. If higher than 70 or O.L.( open line) then it is shot.
Hixheat1 12-12-2010 01:12 PM
If you take the task to replace it try not to touch with fingers oil from hand can cause hot spots latex gloves will help very easy to break
