Trane XL80 Heat Won't Come On - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 08:20 AM   #1
Trane XL80 Heat won't come on
My Trane XL80 furnace is not heating. I am getting the following code: 1 red flash, then 12 red flashes, then 3 red flashes continuously.
What is the problem?
roma24 is offline   Reply With Quote
Old 12-31-2009, 10:18 AM   #2
Need a better (more complete model number and serial number)...XL80 is the family but the model and serial will help pin point. Anyway, the 1 flash and 12 flash don't make sense.......Trane does not have that...a 3 flash means a stuck or open pressure switch...........if there is a continuous slow flash, that means normal, No call for heat; if you get a fast flash, that means normal, Call for heat is present......
Final Final is offline   Reply With Quote
Trane Aux heat modification tj1mcd HVAC 2 12-05-2009 07:24 PM
trane mod# twe060c15fdo no heat, help itsme711 HVAC 1 01-21-2009 09:03 PM
Are Trane heat pumps and Am Std exactly the same? jgtaylorjr HVAC 1 06-01-2008 09:35 PM
