Trane XL 80 Won't Light. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 09:51 AM   #1
Trane XL 80 won't light.
Hey everyone, I'm having an issue with my Trane XL 80. I'm stuck in figuring out if it's the gas valve solenoid, or the control module. Here is whats going on.
When I get my call for heat, my ignitor will light, but when the gas valve is supposed to open, it doesn't.
When I disconnect the wires to the gas valve, I will have 24VAC just like I'm supossed to have. But when it's connected to the solenoid, I only get 9VAC.
Could this be an issue with the solenoid, and causing the voltage drop I'm seeing, or is this an issue with the control board not being able to supply enough current?
cdcamaro9534 is offline   Reply With Quote
Old 02-14-2010, 10:19 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 398
Most likely the gas valve is seizing up, 95%. Give it a good wrap with a crescent wrench or screwdriver handle when it is trying to open. VERY rarely does the board drop the voltage or the transformer get weak.
Old 02-14-2010, 10:13 PM   #3
Looks like it's the solenoid for the gas valve. I figured I couldn't hurt it no more by taking it apart and looking at it.
I applied 24vac with a variable transformer, and all the gas valve solenoid does it buzz, and it won't suck the plunger up to let the gas through. The others seem to work ok. Guess I will be trying to buy one tomorrow.
Old 02-16-2010, 05:01 PM   #4
Well looks like it's not the gas valve. Just bought a new one, and still won't light. I still have only 9vac when connected. Guess I will buy a new control board!
Old 02-16-2010, 05:06 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 398
Be careful to read the instructions CAREFULLY for that board. There was some jumper/retrofit on some of them.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Trane XV80 no flashing light KabbyBarty HVAC 17 02-28-2009 02:20 PM
Trane 80xl, 3 flashes error light - draft pressure problem, help? Xsta HVAC 1 10-14-2007 08:20 PM
