-   -   Trane XL-80 Control Board got wet.... (http://www.diychatroom.com/f17/trane-xl-80-control-board-got-wet-149525/)
brandnewrock8 07-07-2012 10:43 PM
Hello guys, im glad I found a DIY forum for HVAC! I have a bit of a dilemma. I have a Trane XL-80 furnace with the overhead a/c coil. Two days ago my a/c lines froze up, my filter was quite dirty and the coils in my outdoor a/c unit were also dirty (shame on me!). When the lines froze they dripped a considerable amount of condensation onto the filter, and thus the water got into the system while it was running. From there I figure the water was sprayed all over the motor and control board. The furnace cut out completely then. I am getting a solid red led light on my control board, which means I need to replace the board. My dilemma is not so much what is wrong, but what should I do to fix it. Right now I have temporarily jumped the board to supply power to the motor, and the system is working great (thank god, it has been very hot in Michigan this past week), however I understand this is no permantant fix by any means. should I
A) Suck it up and buy a new board ($250)
or
B) Take the board to an electronics repair man and see if he can repair the board. I am thinking its just resistor for the blower (if that makes sense)
Thanks!!
-Brent
techpappy 07-07-2012 11:42 PM
try drying it out thoroughly for a few days then reinstall.. if no go then bite the bullet and replace good luck
Marty S. 07-08-2012 07:38 AM
Brent, furnace control boards can not legally be repaired since they contain the flame proving circuits (kill the power to the gas valve when flame not sensed). Even if it dries out I wouldn't trust it so would advise to buy a replacement. The same with gas valves. Some even have a sticker stating valve must be replaced if exposed to water.
With that said it's your house and equipment so you are free to do as you want.I'm sure there's many gas valves and control boards out there that have been wet and are still functioning just fine. A HVAC company would replace the parts as a CYA measure since they would be held liable should the safeties not work and house burns down. The DIY home owner can't sue themselves if things go wrong.
beenthere 07-08-2012 07:42 AM
Replace the board if it doesn't work after letting it dry out.
brandnewrock8 07-08-2012 08:19 AM
Thanks guys. I was thinking the safe bet would be to replace it, but Ill let it dry out for a few days and try it again. Thanks for the input!
-Brent
biggles 07-08-2012 08:32 AM
let i lay out in the days sun and flip it a couple of times...the solid black relay cube is the supply fan motor power feed..should click when you jump R to G on that board if your filter was packed with dust/dirt check the rounds on that fan squirrel cage inside the air handler
stickboy1375 07-08-2012 09:00 AM
12 Attachment(s)
Ive heard people putting wet cell phones in a bag of rice with help with the drying process since the rice will absorb any moisture, same effect as when they place rice in salt shakers so the salt does not clump together.
Evstarr 07-09-2012 02:16 AM
Rice in the salt shaker works because the larger grains of rice agitate the salt and break up the clumps. A few grains of rice can't hold enough moisture to do anything but postpone the clumping for a few days. Unless you change out your moisture laden rice for new dry rice periodically of course. ;)
alexbest27 07-11-2012 04:32 PM
If you want to prevent this from happening again, OC has some products designed to prevent this. Check out their commercial page and click on air handling systems to see what I'm talking about. I linked to the page below the post. Hope this helps you out and good luck!
beenthere 07-11-2012 04:40 PM
Insulation would have done no good.
techpappy 07-11-2012 04:47 PM
TO Alex..you know who you are..you are wasting our time by posting your OC
ads which are not even close to being specific to the topics at hand..if they are then I suggest you look up the solutions first then let us know each solution specifically applied to the posted problem..that would be beneficial instead of annoying!
