Trane XE90 - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 08:46 PM   #1
Rewards Points: 105
Trane XE90
Is there a wire that controls the fan speed on this model ? Thanks.
gmbwrenchn is offline   Reply With Quote
Old 08-07-2011, 09:02 PM   #2
Yes
Look on the control board. You will see a wire running from the fan to a" tap" on the board marked" cool" and another heat. Black is usually the color for high speed. But refer to the diagram of the motor before making any changes
Master of Cold is offline   Reply With Quote
Old 08-07-2011, 09:10 PM   #3
Rewards Points: 105
Thanks I'll check it out. What are the speeds, if you know off hand. Low,med,hi? Or other.....thanks.
Old 08-07-2011, 10:51 PM   #4
Depends on the fan, some are 3 speed, some are 4
Old 08-08-2011, 07:51 AM   #5
Rewards Points: 163
My previous Trane XE90 had a four speed PSC blower motor. If you change the speed make sure you check the temperature rise to make sure it's still within specifications. The specifications are posted on the inside panel of the furnace.
kb3ca is offline   Reply With Quote
Trane xe90 lmartinez01 HVAC 9 05-26-2011 01:50 PM
Trane XE90 clicking gmbwrenchn HVAC 14 01-23-2011 08:26 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Trane XE90 bjofss HVAC 4 01-21-2009 07:08 PM
