Trane Xe90 - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 01:06 PM   #1
Trane xe90
Replaced the capcitor and blower wheel however the air is blowing hard through the vents. Do you think I need to replace the blower motor?
Coils? Ducts?
Single mother. Help?
lmartinez01 is offline   Reply With Quote
Old 05-25-2011, 07:30 PM   #2
HVAC Tech
Ducthunter's Avatar
Is this for heat or cooling? If it's heat you can lower the speed. If it's cool it needs to be ran on certain speeds according to your location, out door unit size, etc. If it's a new blower wheel it may be a lot cleaner then your old one which would make it move a lot more air. Your ducting could also be undersized which will cause inefficient system operation and high velocity air from the registers
Ducthunter is offline   Reply With Quote
The Following User Says Thank You to Ducthunter For This Useful Post:
lmartinez01 (05-26-2011)
Old 05-26-2011, 07:29 AM   #3
trane xe90
It is for cooling and indoor unit. Blows cool just not adedquate enough air flow. Almost as if it was like someone blowing on you. Do you think there may be a something wrong with ductwork. This is an old unit at least 10 yrs or more? At first we head something rattling, the blower fan was making a lot of noise and found something like a piece of metal that fell down on blower wheel. Very strange.
Old 05-26-2011, 07:52 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
In post number 1 you state it's blowing hard and in post number 3 you say not adequate air flow. Which is it? And if it's the latter, how was the system running (blowing) before you worked on it?
Any metal that fell off can only be one thing, your blower wheel came apart.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 05-26-2011, 07:56 AM   #5
I'm guessing you need a new blower wheel and now possibly another new blower motor as well. Your fan is running backwards if it used to run normally and produce enough air flow and now it's not.
Old 05-26-2011, 07:59 AM   #6
Okay, you replaced the wheel and cap but not the motor. Did you put the wheel back in the right way?
Old 05-26-2011, 08:01 AM   #7
Trane
I meant to say it is hardly blowing. Prior to working on it there was a hard banging noise and again hardly any air blowing. I was told last year during cleaning that I would eventually need a new motor and blower wheel.
When work began the motor would start the wheel then stop and I spoke to a AC man here where I work and he said as long as the motor was working I most likely needed a capicitor, replaced that, then seemed fine air worked cooled off house, set thermostat to 70 but next day it seemed the system just ran and ran and ran temp in house went up to 76.
My next step is to look at coil and clean that off and then if that doesn't work I guess I need to check ducts? I don't know how I am going to do that?
Old 05-26-2011, 08:02 AM   #8
trane
Yes, wheel is in correctly.
Old 05-26-2011, 01:42 PM   #9
Is your evaporator coil froze up solid? That could cause loss of air flow.
DougEFresh is offline   Reply With Quote
The Following User Says Thank You to DougEFresh For This Useful Post:
Old 05-26-2011, 01:50 PM   #10
Trane
I am not sure. I will have to look at it tonight. Is that piece hard to locate and would it be on the unit inside the house?
Trane XE90 clicking gmbwrenchn HVAC 14 01-23-2011 08:26 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
Help me compare Trane heat pumps pls tomseeley HVAC 3 04-02-2010 05:54 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Trane XE90 bjofss HVAC 4 01-21-2009 07:08 PM
