Trane XE80 Venting With PVC ? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2015, 01:04 PM   #1
Rewards Points: 60
Trane XE80 venting with PVC ?
guys i have a Trane XE80 furnace and want to know if i can vent it using PVC instead of aluminum vents. I was told on some high efficiency furnaces we can vent with PVC ?
any info is greatly appreciated.
thank you.
xclaim is offline   Reply With Quote
Old 01-20-2015, 01:13 PM   #2
Rewards Points: 7,672
If you want to vent with pvc, you need a 90%+ efficient furnace. The exhaust from an 80% would melt the plastic.
If you insist on doing this yourself, at least call a gas fitter to deal with the gas and venting.
The furnace has to be matched to the ductwork and set up correctly.
user_12345a is online now   Reply With Quote
Old 01-20-2015, 02:10 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
Yours is a mid efficiency unit and the exhaust will melt PVC.
Old 01-20-2015, 03:43 PM   #4
An old Tradesmen
Rewards Points: 7,304
As other s said. No, metal vent only. Must be a 90% or better to vent in plastic.
Old 01-20-2015, 05:23 PM   #5
Rewards Points: 582
just making sure you got the right message..no. no. no. 80% furnaces metal pipe...
Old 01-21-2015, 05:27 AM   #6
Rewards Points: 3,832
People have done it before........and almost burned their house down and/or gassed themselves in the process.
Remember, your playing with a controlled explosion. Make sure you put it in correctly.
roughneck is online now   Reply With Quote
Old 01-21-2015, 06:14 AM   #7
Rewards Points: 1,294
Don't know about your area as you chose not to include that info but, in my area we are mot allowed to use aluminum for exhaust venting either. It has to be steel
danpik is offline   Reply With Quote
Old 01-21-2015, 06:09 PM   #8
An old Tradesmen
Most B vent is aluminum on the inside. I believe you mean your not allowed to use aluminum single wall pipe.
Old 01-21-2015, 06:34 PM   #9
Yes, We are not required to use double wall inside until it is inside an enclosure such as a chimney chase.
The Following User Says Thank You to danpik For This Useful Post:
xclaim (02-18-2015)
Old 02-18-2015, 07:57 AM   #10
Rewards Points: 60
got it - i used double wall metal pipes - the ones rated for furnaces. thanks all for the clear and precise info.
Trane XE80 Troubleshooting fpwireman HVAC 4 11-14-2014 05:18 PM
Trane XE80 with Error Code 5 WaldoLake HVAC 7 01-07-2013 01:26 PM
Trane XE80 - No heat, No suprise ggutier49 HVAC 0 01-28-2011 08:44 AM
Trane xe80 no heat tackman HVAC 9 11-05-2010 01:33 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
