Old 02-07-2010, 11:45 AM   #16
An old Tradesmen
Trane XE80 only fan comes on
That the contactor is closed. And that the fan motor is receiving 240 volts along with the compressor.
Old 02-07-2010, 11:46 AM   #17
cycle the breaker and it seems to be fine.
berr3555 is offline   Reply With Quote
Old 02-07-2010, 11:51 AM   #18
An old Tradesmen
Did you get a 240 volt reading at the line and load terminals of the contactor?
If you don't use a meter. You don't know.
Old 02-07-2010, 11:56 AM   #19
The capacitor connecting is alittle bulge it looks like I need one of them, proble is where to find one on a sunday.
Old 02-07-2010, 11:58 AM   #20
Also the board in the outside unit is doing a slow blink similar to the inside unit.
Old 02-07-2010, 11:58 AM   #21
An old Tradesmen
Either call a tech. And see if they will sell you one.
or, just leave your stat switched to emergency heat until you get one tomorrow.
Old 02-07-2010, 12:00 PM   #22
An old Tradesmen
Probably the heart beat to tell you it is receiving no call for heat or cooling.
Old 02-07-2010, 12:09 PM   #23
I measure voltage in what I believe is the contactor and the capacitor, and it reads around 110 volts in the four connections in the contactor and the 3 connections of the capacitor.
Old 02-07-2010, 12:13 PM   #24
An old Tradesmen
Don't read to ground.
You read T1 to T2.
L1 to L2.
Don't try reading voltage at the cap. Since when the unit is running, the voltage will be higher.
Old 02-07-2010, 12:23 PM   #25
ok, will read again.
Old 02-07-2010, 12:29 PM   #26
read 220 in one side and 0 in the other while off and 220 in both while running.
Old 02-07-2010, 12:31 PM   #27
About the capacitor it seems that it don't last but two years, is that normal.
Old 02-07-2010, 12:32 PM   #28
An old Tradesmen
Sign of a bad motor.
Old 02-07-2010, 12:33 PM   #29
An old Tradesmen
Then cap and or motor are bad.
If cap only last 2 years. Motor has a problem. or your using the cheapest saps made.
Old 02-07-2010, 12:50 PM   #30
The motor had a real loud squeal and I replaced it last summer, it was recommended to change the capacitor too but at the time the capacitor was not much more than a year old so I didn't. Thank you everyone for your help I will let you know how the new capacitor does.
Trane XE80 Furnace fan won't stop running Luv2Auction HVAC 2 01-07-2013 10:05 AM
TRANE XE80 - 2 red flashes - intermittant Thomasv HVAC 13 01-28-2010 10:26 AM
Trane XE80 - No ignition ggutier49 HVAC 3 10-17-2009 10:38 PM
Trane XE80 not(?) hot enough rossl56 HVAC 5 11-28-2008 03:34 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
