-   -   Trane XE80 not(?) hot enough (http://www.diychatroom.com/f17/trane-xe80-not-hot-enough-32534/)
rossl56 11-24-2008 12:59 PM
I just bought a home with a trane XE80 (no central air) installed in mid to late 90's. It works but "I think" the air should be warmer.
The heat comes on and off fine. Whatever temp (LUX Programable Thermostat) I set is reached before it turns off/on.
In comparison to other systems the heat blowing out of the registers doesn't feel as warm with my system. My friends air feels noticably warmer.
I've had the ducts cleaned recently and the filter is clean.
Is there anything I could check myself? Is there any adjustment in the furnace?
beenthere 11-24-2008 04:05 PM
If its heating the house. The air doesn't need to be warmer.
Your blower may be set at a higher speed. You could lower it. But you could end up with rooms that don;t heat as well then.
rossl56 11-25-2008 08:38 AM
Thank you for the answer.
I think you are correct about the blower setting. There are 2 rooms (1 in particular) that may require the higher setting to reach.
The blower is set to a VERY high speed. In the living room you can actually feel a draft when the heat is on. I think the draft is caused by the air coming out of the register stirring the air in the room so much. That is one of the main reasons that I would like the heat to feel warmer. There are a couple of rooms that get more heat/air than others (these are obviously closer to the furnace.
Can anyone tell me the location of the blower speed so I can try to reset the dampers in the ducts?
beenthere 11-25-2008 06:12 PM
It will be on the furnace control board in teh blowe compartment.
Turn power off before opening.
rossl56 11-27-2008 11:56 AM
There is a sticker on the access door that states there are 4 wires for the fan that go to the Control Unit. They are labelled:
COOL, HEAT, PARK, PARK (What does park mean?)
There is also a white wire contacted directly to the fan
There is also a "Fan Speed Table" that states the following:
(1) Red - Low
(2) Yellow - Med Low
(3) Blue- Med High
(4) Black - High
The wires (with push on connectors) are now connected as follows:
Cool - Black (I do NOT have A/C)
Heat - Blue (Is the fan now set for Medium High for heating?)
Park - Red
Park - Yellow
Would I just swap the yellow and blue at the control unit (to set the heat/blower to med-low)?
beenthere 11-28-2008 02:34 AM
Park is where you "park" unused motor speed wires.
Your current heating speed is med high.
Move that blue wire to the park terminal of the speed you want to use.
And connect that speed wire to the heat terminal.
