Trane XE80 - No Heat, No Suprise - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 08:44 AM   #1
Trane XE80 - No heat, No suprise
Hey guys
I have an ancient Trane XE80 furnace in the basement. It has been slowly falling apart for years and i have been piecing it back together. This year, this week to be specific, it has decided to only intermittently give us heat.
There is no error code on the board, just a normal call for heat. The HSI works fine, the gas clicks on and will ignite at times. Sometimes it is a inconsistent ignition sequence that keeps repeating until only the blower is working. Other times it follows the expected route of heating until it has reached the correct temp.
The control board is new as of last year. The air filter is new as of a week ago. There doesnt seem to be any blockages. The flame sensor was just cleaned. Any help would be GREATLY appreciated.
Thank You
P.S. If you can please post pictures because i have no manual that points out specific parts.
ggutier49 is offline   Reply With Quote
Trane Aux heat modification tj1mcd HVAC 2 12-05-2009 07:24 PM
Trane Heat Pump Not Blowing Cold JbIcon HVAC 3 09-01-2009 10:15 AM
trane x19i heat pump MrSnapRon HVAC 8 08-29-2009 01:17 PM
Trane XE80 not(?) hot enough rossl56 HVAC 5 11-28-2008 02:34 AM
Are Trane heat pumps and Am Std exactly the same? jgtaylorjr HVAC 1 06-01-2008 09:35 PM
