11-19-2011, 11:34 PM
#16
Trane XE80 furnace, best filter to buy
Originally Posted by yuri
From your earlier post #5 "NaturalAire Standard pleated filters (MERV 8) made by Flanders. $8 for a 3 pack at HD."
$8 for 3 sounded too cheap to me. $8.97 for 1 is more like it and OK. Nobody can recommend when to change it. Depends on how much dirt you get and how long your furnace runs etc. Pull it out once a month and you should be able to see the light thru it. compare it to a clean one then. I had a limit control in one of those furnaces blow and it is a lower setting one so you want to prevent that and change it once a month if necessary.
I disagree yuri,,,,,,ashrei standards dictate that all 1'filters be replaced every 30 days........
11-19-2011, 11:46 PM
#17
I'm Your Huckleberry
I use in my own home the cheapest of the cheap filters that I change every 3-4 weeks, dependent upon how much hair my dogs have shed.
11-20-2011, 08:55 AM
#18
Hvac Pro
I wonder if they have rules about doing a PM preventative maintenance on a furnace which no one will follow either.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-20-2011, 10:07 AM
#19
Once a month to me seems way too much. I don't live in a desert.......
02-11-2012, 11:27 AM
#20
Merv 7 or 8 True Blue from HDepot is what is recommend. About the same price. I think yours is about the same but those guys don't use MERV which is the industry standard. I don't like washables as they plug too easy and can overheat your furnace or freezeup your AC.
is this the one you were talking about?
http://menards.com/main/plumbing/hea...646-c-6856.htm
02-11-2012, 11:38 AM
#21
Hvac Pro
That is a MERV 11 and a lot tighter and restrictive to airflow than Merv 7or 8. You would need someone to check the heat rise in the furnace AND the AC performance/temps to make sure it does not cause trouble. Correct company but that filter may be too tight for you.
02-11-2012, 11:54 AM
#22
than it's gotta be this out of stock one.
http://www.menards.com/main/plumbing...589-c-6856.htm
02-11-2012, 12:02 PM
#23
Professional
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-11-2012, 12:11 PM
#24
Originally Posted by hvactech126
To be on the safe side which way should the filter point towards?
02-11-2012, 12:12 PM
#25
Professional
arrow ALWAYS points towards the furnace.
02-11-2012, 12:18 PM
#26
Great so I have mine pointed to the right.
02-11-2012, 12:25 PM
#27
These Flander's naturalaire filters seem weak. Here's how mine looks after 3 months.
02-11-2012, 12:27 PM
#28
Professional
weak? That is really dirty!
#29
They have a material that make them seem like the filter is really dusty, but it isn't.
02-11-2012, 12:28 PM
#30
Meaning the material is soft and the fibers pull off easily. That isn't all dust you see there. Yes it's dirty after 3 months.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
