11-19-2011, 02:49 PM
#1
Trane XE80 furnace, best filter to buy
Our home was built in 1996, we are the 2nd homeowners. This furnace originally had a washable filter, but over the years I have been using the standard 3M filters 700, $8.88 at Walmart. Should I stay away from the washable filters with this model ?
11-19-2011, 04:11 PM
#2
Hvac Pro
Merv 7 or 8 True Blue from HDepot is what is recommend. About the same price. I think yours is about the same but those guys don't use MERV which is the industry standard. I don't like washables as they plug too easy and can overheat your furnace or freezeup your AC.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-19-2011, 04:20 PM
#3
I have a 16x24x1 size, let me see who has that one.
11-19-2011, 04:23 PM
#4
Hvac Pro
16x25 is common and you can leave the extra 1" sticking out the front of the filter rack if there is room. Lowes and other places may have them too.
11-19-2011, 04:24 PM
#5
what about this one?
NaturalAire Standard pleated filters (MERV 8) made by Flanders. $8 for a 3 pack at HD.
11-19-2011, 04:30 PM
#6
Hvac Pro
Sounds too cheap too me but I don't know the cost of living in your area. 3pk 16x25x1 True Blue is $15-20 Cdn and our dollar is about even with the US. $5-8 apiece sounds reasonable to me.
11-19-2011, 04:41 PM
#7
I just can't find my size online at home depot for the ones you described..
11-19-2011, 05:20 PM
#8
If you can read print through the filter when its clean, don't use it......also remember regardless of what the package says, all 1' wide filters are only god for 30 days.
The Following User Says Thank You to harleyrider For This Useful Post:
11-19-2011, 05:54 PM
#9
I bought the NaturalAire Standard pleated filters (MERV 8) made by Flanders. $8.97 for 1. Change it in 3 months?
11-19-2011, 06:17 PM
#10
see post #8
11-19-2011, 06:27 PM
#11
Originally Posted by harleyrider
see post #8
I did read that, but I'm also trying to get some other opinions. thx
11-19-2011, 06:42 PM
#12
Hvac Pro
From your earlier post #5 "NaturalAire Standard pleated filters (MERV 8) made by Flanders. $8 for a 3 pack at HD."
$8 for 3 sounded too cheap to me. $8.97 for 1 is more like it and OK. Nobody can recommend when to change it. Depends on how much dirt you get and how long your furnace runs etc. Pull it out once a month and you should be able to see the light thru it. compare it to a clean one then. I had a limit control in one of those furnaces blow and it is a lower setting one so you want to prevent that and change it once a month if necessary.
The Following User Says Thank You to yuri For This Useful Post:
11-19-2011, 06:56 PM
#13
Since I live in WI I may have to change it more frequently in winter.
11-19-2011, 07:17 PM
#14
Hvac Pro
Yep. It is false economy to not change it regularly. Causes the furnace to overheat and shortens its life and the life of the motor.
11-19-2011, 08:45 PM
#15
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
