Trane XE80 With Error Code 5 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 04:52 PM   #1
Trane XE80 with Error Code 5
I have a 1997 vintage Trane XE80, which would cycle on for heat, Gas burners will light but for only a second or two then go off. The unit has a White Rogers Model 50A50-471 controller, The controller is flashing error code 5: Flame Sensed with Gas Valve Off. After reviewing post on this forum I remove and cleaned the flame sensor, no change. I then changed out the flame sensor with one from a second furnace. Same results.
Does this mean the controller need to be changes?
Thanks,
WaldoLake is offline   Reply With Quote
Old 01-04-2013, 06:46 PM   #2
HVAC Tech/ Browns Fan
You need to clean sensor . You maybe putting other units dirty flame sensor in there too,.
Tator1076 is offline   Reply With Quote
Old 01-04-2013, 09:04 PM   #3
Sensor has been cleaned. Other sensor was firing the other furnace.
Old 01-05-2013, 10:31 AM   #4
An old Tradesmen
Rewards Points: 6,070
Its not the flame sensor. A dirty flame sensor won't give you a Flame detected with gas valve closed error. Since if its dirty, it generally can't detect a flame.
Either a reversed electrical polarity, poor ground, or the board is bad. Those would be the common problems for that error code when there is no flame.
The Following User Says Thank You to beenthere For This Useful Post:
WaldoLake (01-05-2013)
Old 01-07-2013, 07:07 AM   #5
I'm having this same problem now. Were you able to fix yours? What ended up being the problem?
mmsall is offline   Reply With Quote
Old 01-07-2013, 08:39 AM   #6
Roofmaster
Rewards Points: 2,172
The controller board is held in with a few screws, in my case (carrier) one of those screws grounds the board to the frame of the furnace. Long use and the screw can back out a little, connection can corrode, No Ground. I would say loosen All screws a turn or two, spray with contact cleaner, and re tighten screws. By all screws I mean the thermostat leads too. Pull off the spades, spray, emory, spray, put back.
Old 01-07-2013, 08:46 AM   #7
Thanks, I'll check the ground on the controller, today
Old 01-07-2013, 02:26 PM   #8
Roofmaster
Thats a starting point, and a bad ground can really cause problems.
Tags
controller , flame sensor , trane , xe80
Newbie has issues with Trane XE80 hayescary HVAC 26 12-11-2011 10:46 AM
Trane XE80 Burners Won't Ignite BFR HVAC 11 12-12-2010 07:33 PM
Trane xe80 no heat tackman HVAC 9 11-05-2010 02:33 PM
Trane XE80 - No ignition ggutier49 HVAC 3 10-17-2009 10:38 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
