Trane XE78 One Burner Wont Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 10:09 PM   #1
Talking
Trane XE78 One Burner wont ignite
I have a trane xe78 furnace. It has a "glow stick" ignition and 5 burners. The last burner (furthest from the ingition) has the flame sensor on it. All of the burners ignite except for the last one with the sensor so the whole thing shuts down after a few seconds. I'm wonder what would cause this. When I move the sensor to the first working jet (next to one that isn't working) it stays on and runs just fine. Could the last gas valve be clogged for some reason or could there be a fail safe for a bigger issue keeping the 5th burner from igniting so it will shut down? Any help would be much appreciated.:
ruckamuck is offline   Reply With Quote
Old 10-29-2010, 10:23 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
The orfice on the last burner could be clogged
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
ruckamuck (10-29-2010)
Old 10-29-2010, 10:31 PM   #3
recommend just getting a thin wire brush to clean it or will I have to take the piping apart?
Old 10-29-2010, 11:08 PM   #4
HVAC / Plumbing
If you have the room,you may be able to clean it without removing
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
transformer failure in a Trane XE78 turtleescape HVAC 7 07-19-2010 08:34 PM
Pilot light -trane xe78 skippy47 HVAC 5 03-02-2010 05:34 PM
Trane XE78 No Glow cdaviswa HVAC 9 01-03-2010 01:34 AM
Gas Hot water heater, burner will not ignite hammerdome Plumbing 8 10-14-2009 06:04 PM
Utica Boiler Burner Won't Ignite jackjr1948 HVAC 8 03-02-2008 09:14 PM
