Trane XE1200 Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 04:25 PM   #1
trane XE1200 heat pump
I have a Trane XE 1200 heat pump, when I have the thermostat set on hot, run the neele over the ambient air temp, the air handler cycles, and I hear a solenoid pull in at the unit outside, but I hear no motor ( compressor ) start
Same thing when I am on Cool
Jimed is offline   Reply With Quote
Old 11-12-2012, 10:49 PM   #2
Rewards Points: 1,192
First,check for power at outside disconnect.
bobelectric is offline   Reply With Quote
Old 11-13-2012, 04:27 AM   #3
An old Tradesmen
Rewards Points: 7,268
Yep, check for tripped breaker.
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 05:18 PM
Trane Heat pump revmred HVAC 1 10-20-2012 09:48 PM
Heat Pump Crisis Part II Doc Holliday HVAC 58 12-07-2011 09:14 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 09:22 PM
Trane Heat pump capacitor exploded! swiffy25 HVAC 18 01-19-2011 05:48 AM
