Trane XE1200 Crankcase Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 09:53 AM   #1
Question
Trane XE1200 crankcase heater
Does anyone have a good source for finding parts? I have a Trane XE1200 with a blown crankcase heater. I can't find a parts list for my unit aside from the schematics, which I already have.
Thanks.
jdsimpkins is offline   Reply With Quote
Old 05-10-2012, 11:18 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Do you actually need the heater? I mean, do you live up north where it's sub zero in the winter?
Down here we simply remove them altogether.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-10-2012, 01:00 PM   #3
I'm going to bypass it for now. But I just don't want to leave it like that if I can find one inexpensive. I may want to put in a heat pump and don't want this to hold me back.
Old 05-10-2012, 01:10 PM   #4
Don't bypass it, completely remove it from circuit. Turn the power to the condenser/heat pump by way of breaker, remove the lid and trace back the heater wires to the the contactor. You may not need to even remove the lid if you can see from the top and identify through the service panels which wires they are. Three minutes and its done.
Those things sit in dirt and water on the very bottom and corrode, eventually breaking and since they are on the high voltage side they trip the breaker when they break.
They are inexpensive to replace. Your neighbor's heat pump probably has one.
Just kidding, don't do that.
Thanks.
Old 05-10-2012, 03:19 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
post a full model number for the unit and I can find you a part number. FYI, if they are rusted in they can be a pain to get out and some you can't get out and have to use a bellyband as a replacement.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-10-2012, 03:36 PM   #6
hvactech126,
Thanks. The Model number is TTP018C100A2. As far as the difficult to remove alert, so I've heard. I haven't tried to remove it yet so I don't know the condition. Thanks for the warning.
Old 05-10-2012, 03:55 PM   #7
AKA HVACTECHFW
sump heater = HTR01298
Retaining spring = SPG00200
IT IS WHAT IT IS
Old 05-10-2012, 04:03 PM   #8
Originally Posted by jdsimpkins View Post
hvactech126,
Why are you wanting to remove it in the first place?
Thanks.
Old 05-10-2012, 05:03 PM   #9
Because I want to replace it. If I need the bellyband style heater then so be it.
Old 05-10-2012, 07:33 PM   #10
REP
Oh for God's sake,there is a differance between being frugal and just being cheap.
Any Trane or American Standard dealer can get you the correct crankcase heater.Its not that expensive .Why reinvent the wheel???
REP is offline   Reply With Quote
Old 05-11-2012, 04:00 AM   #11
An old Tradesmen
Rewards Points: 7,816
And the OEM heater is so much easier to put in then a belly band.
Old 05-11-2012, 09:53 AM   #12
Slow down and read the earlier posts. I never asked for a bellyband. It was suggested in case I can't remove the correct part. My initial question was where can I find the part I need, which equates to not being cheap by the way.
Old 05-11-2012, 12:42 PM   #13
An old Tradesmen
My response was to the post that suggested a belly band.
The part is available from Trane/American Standard dealers, and distributors. And several online HVAC parts suppliers. Just type "Trane crank case heater" into your search bar. Pick the plce that ships faster.
Old 05-11-2012, 02:30 PM   #14
beenthere,
Thanks for the tip.
Old 05-12-2012, 08:49 AM   #15
Rewards Points: 1,192
Time for an upgrade.
bobelectric is offline   Reply With Quote
Tags
crankcase heater , parts list
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Fan motor for XE1200 Trane no running but have a frustrating problem spg112357 HVAC 13 01-08-2012 03:54 PM
Question on Carrier Crankcase Heater Larry H HVAC 8 12-11-2011 12:24 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Replaced blower wheel - now Trane heater will not blow hot air Skiphorn HVAC 1 01-14-2011 10:31 PM
