Trane Xe1000 Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 04:06 PM   #1
Trane xe1000 Problem
My trane xe1000 runs inside but doesn't blow cold air and the fan outside doesn't turn on. I've read some threads on this topic and the common fix I've seen is to replace the capacitor. I removed the cover to the machine and I'm not sure if the white cylinder on the bottom is the capacitor or not since it only has two connectors at the top instead of the three that I've typically seen. It also doesn't look like its bulging. Am I heading in the right direction by replacing the capacitor or could it be something else. Thanks
dukes1234 is offline   Reply With Quote
Old 07-09-2011, 04:11 PM   #2
JJboy's Avatar
Top Capacitor is for Fan. You can test it with multimeter.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-09-2011, 08:00 PM   #3
Should check the breakers and fuses in the outdoor disconnect, if it has fuses. From what i can see of the condensing coil it appears jam packed with debris. This will cause high head pressure and your compressor could over-amp, trip a breaker or blow a fuse. The condensing coil must be washed out with a hose. The best way is to take the top off and hose it from the inside out. If your condenser has sheet metal grills around it, sometimes it helps to remove them for cleaning.
SKIP4661 is offline   Reply With Quote
Trane XL1200 - Outdoor Unit Problem snifred81 HVAC 5 08-07-2012 02:53 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
Trane XE 1000 Fan Problem Flathead64 HVAC 15 07-01-2009 10:08 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
