Trane XE1000 Outdoor Fan Connection - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 03:56 PM   #1
I have a Trane XE 1000 A/C. I lifted the cover off the outside unit and accidentally disconnected the fan from the unit. There are three wires: purple, brown, black. How do I reconnect them so the fan will work?
Thanks in advance for your help.
ggschuler11 is offline   Reply With Quote
Old 06-24-2012, 04:02 PM   #2
JJboy's Avatar
Brown and purple goes to the capacitor
Black to the contactor
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-24-2012, 04:25 PM   #3
Attached are two pictures: entire unit and the focused pic on the capacitor.
I only see one available spot on the capacitor and would that house the brown or purple wire?
Also, for the picture facing the entire unit, is the small electrical component in the right hand corner of the picture the contactor?
Trane XE1000 Outdoor Fan Connection-ac-unit-picture.jpg   Trane XE1000 Outdoor Fan Connection-capacitor-picture.jpg
Old 06-24-2012, 04:41 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
the capacitor on the right, not the one you took a close up of..... Purple to the same terminal as the brown/red wire and brown to the other terminal and black plugs into that blue wire with the pink cover on it.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-24-2012, 04:43 PM   #5
JJboy's Avatar
What is the capacitor values? Also close up pictures.
Try to connect like this picture
Old 06-24-2012, 10:17 PM   #6
JJBOY and HVACTECH126: Your illustrations worked. The outdoor unit is now working. Thanks very much for taking time to respond to my post. Your help is much appreciated. Have a great evening.
Old 06-24-2012, 10:23 PM   #7
JJboy's Avatar
Sensor Fell off Trane XE1000. What is it? Krell HVAC 18 09-25-2011 02:03 PM
Loud Snap from Trane XE1000 after I shut off power Krell HVAC 4 07-19-2011 10:14 AM
Top of Trane XE1000 Heat Pump won't come off Krell HVAC 10 07-09-2011 07:52 PM
Trane xe1000 Problem dukes1234 HVAC 2 07-09-2011 07:00 PM
Trane XE1000 compressor not coming on line. Flathead64 HVAC 8 11-03-2009 06:29 PM
