Old 06-19-2009, 05:59 PM   #16
hvaclover's Avatar
Trane XE1000 compressor question
Originally Posted by Yoyizit View Post
That was covered under the "other things being equal." Designing for reliability gets pretty tricky; that's why there is MIL-STD-217.
"A 14 SEER isn't anymore complex then his old XE1000."
Then how do they get the higher efficiency?
More parts connected so you get redundancy may be more reliable; more parts wired in sequence is less reliable, other things being equal.
You miss my point Yoyzy. Iam saying that the higher seer ratings models(and I assumed everyone knew that meant high end equip (well that statement is redundant. Everybody selling hvac already know 14 SEER and higher have all the protective devices I am refering to)).
In the infantcy of hvac all condensers came with fan cycling, low press control, high press control, crankcase heater, suction accumulator, discharge muffler, and external overcurrent and over heat protection.
They protected the equip against all the problems that could kill a compressor.
Costs caused these protective devices to be replaced by a heat only sensing thermostat buried in comp windings.
We see these devices make a return in the higher end equip.
They make the equipment more reliable. I won't argue why, if you know hvac it's self evident.
The bottom line is protect the compressor from all the hazards that kill a cmpressor and you have a longer lasting unit. That spells reliability to me.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 06-19-2009, 06:09 PM   #17
An old Tradesmen
Larger indoor and outdoor coils.
Rated the the condenser at a lower condensing temp. Where it draws lower amperage.
Lower HP condenser fan motors.
Old 06-19-2009, 09:55 PM   #18
It was a dark and stormy
Yoyizit's Avatar
Thanks for your answers. I've got more study to do, for sure.
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 10:01 AM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 11:46 AM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 07:23 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 01:16 PM
