Trane Xe 90 Furnace Blower Running Constantly. - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 09:57 PM   #1
Trane xe 90 furnace blower running constantly.
I have not ran my furnace for a couple years now and attempted to fire with no luck. The main blower motor runs constantly no matter if it is calling heat or ac. I set the thermostat to heat and set it a couple degree higher than room temp. The combustion blower never comes on, the main blower runs constantly and the control board led is off. I have check the power at the fuse and I do have the 24 vac. Does anyone have any suggestions as what could cause this situation?
sshaneparsons is offline   Reply With Quote
Old 12-08-2011, 10:04 PM   #2
are you getting any fault codes ? sounds like a stuck fan relay
harleyrider is offline   Reply With Quote
Old 12-08-2011, 10:07 PM   #3
No lights on the control card.
Old 12-08-2011, 10:08 PM   #4
no i do not have any light code showing.
Old 12-08-2011, 10:50 PM   #5
going to need a model number and a picture of the furnace with the doors off would be great
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Carrier Weathermaker Gas Furnace - No blower for heat nerdbit HVAC 5 09-20-2011 10:31 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
gas furnace whistling when on, not when blower on newguy2010 HVAC 0 12-03-2010 01:58 PM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 09:14 PM
