Trane Xe 90 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 01:15 PM   #1
trane xe 90 furnace
I just replaced my control module and tried to fire up the furnace but now I have a signal indicating "open rollout switch". Where and what is the rollout switch and can I do something to fix the problem?
tsbreier is offline   Reply With Quote
Old 11-01-2011, 02:21 PM   #2
biggles's Avatar
rollout is when the flame foats out from the burner....might be tripped MANUAL RESET right on it? cap tubing 2 wires going to it and the board is seeing it open...check the wiring from the switch into the board right terminals
Old 11-01-2011, 06:48 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
you must have used an aftermarket board. That board requires a jumper (provided with the board) that must be put into the molex plug for the board. Please read the instructions that came with your new board.
Trane application - Jumper wire 151-2906 (provided with
control) must be installed on the furnace from R01 to R02 of the
12-pin connector.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Help TRANE XE-80 furnace squeed HVAC 14 12-31-2014 11:29 PM
need help troubleshooting Trane gas furnace pocketfarkel HVAC 4 10-22-2011 12:12 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Lennox G61MPV vs. Trane XV95 Furnace CompuPsych HVAC 2 11-21-2008 08:20 PM
Trane XE 90 Furnace Masterdrafter HVAC 1 02-01-2007 05:54 PM
