Trane XE 80 Vent Motor Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2008, 10:56 AM   #1
Trane XE 80 vent motor replacement
Where can I purchase the fiberglass gasket? Or is it safe to use high temp. silicon / RTV?
DJfixer is offline   Reply With Quote
Old 12-26-2008, 12:09 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 382
You can use red RTV silicone as long as you put a large/healthy/good bead on the ventor and the collector box and make sure it makes GOOD contact/oozes out a bit. Then let it cure for 8 hrs or more B4 you fire it up or it will ruin it. The gasket is a better choice and some heating suppliers will sell fake asbestos gasket material to make one from or try get it from Trane.
Old 12-26-2008, 01:07 PM   #3
Yuri- I contacted a local heating supplier... I can purchase a sheet of fiberglass gasket material, about 1/8" thick. I will try making a gasket out of this material. Any suggestions? Thanks for your help!
Happy New Years!
Old 12-26-2008, 02:15 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 382
Put it over the hole on the collector box and trace it out by tapping it lightly with a ball peen hammer to make an imprint. Or poke small holes to make the cutout circle. Put a couple dabs of RTV silicone on the collector box to hold the gasket in place while fastening the ventor fan on.
Good Luck
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
