Trane Xe-80 Not Ignating - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 12:07 PM   #1
Trane xe-80 not ignating
I have a Trane XE-80 A/C heating unit, the heat is no working.
No light is flashing on the door panel, blower comes on, ignater gets red but the fire does not come on all the time, fan start but it blows cold air, at times it does fire but most of the times it doesn't. I replaced the thermostat but the problems still continues. Does any one has any sugestions.
PAZYAMOR1 is offline   Reply With Quote
Old 10-21-2012, 05:03 PM   #2
how
Rewards Points: 1,104
That combo of problems could be a faulty board or the thermostat.
I would follow your thermostat lines into the furnace where they attach to R, W & G. Turn off furnace power. Make a note of which goes where and remove them. Put a jumper between R & W and turn the furnace power back on.
Let us know what happens.
how is offline   Reply With Quote
Old 10-21-2012, 06:14 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Remove the blower door so you can see the LED on the control board. Tape the door switch with electrical tape. (only for testing purposes) let it run a cycle and then note the flash code. Some times you can't see the LED through the viewing window. During a call for heat the LED should be flashing fast. In standby (no call for heat) it should flash slow. During a fault it should flash X times and then pause and then flash X times etc...
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Trane / American Standard air handler blower fan never shuts off Flt_Simulation HVAC 7 09-20-2012 02:34 PM
Trane Thermostat Replacement roadbiker255 HVAC 7 07-24-2012 02:29 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
