Trane XE 80 High Temp Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2013, 03:34 PM   #1
BCS
So, my furnace suddenly stopped working. I have a trane xe 80 and my High temp limit switch open LED flashing light code appeared.
I did some research and thought it was due to a clogged filter. I changed out the filters and it started up again. Thought that was the fix, but the burners went out and the same code again.
Killed the power, and took out the limit switch, hooked it up to my multimeter, but according to the read out it was "closed" and not "open"
Perhaps I am reading it incorrectly, but someone in the biz told me that if the read out in OHM setting is "OL" then it's open and if it reads 0.0 it's closed?
So based on that information, I ruled out the defective limit switch. I cleaned the thermocoupler and igniter but still getting the same code.
I've looked around for a reset button, but there isnt one and i've looked carefully all over the place.
Do I assume it's the circuit board that's bad? Everynow and then, I can get the burners to go, but it's only a matter of time before they shut off and the same code.
Any ideas?
BCS is offline   Reply With Quote
Old 11-17-2013, 04:06 PM   #2
An old Tradesmen
Rewards Points: 7,816
Do you have central A/C. If so, when was the last time the indoor coil was cleaned.
Old 11-17-2013, 04:09 PM   #3
BCS
Yes central AC. Not sure when the coil was cleaned. Where would that be?
Old 11-17-2013, 04:12 PM   #4
An old Tradesmen
On an upflow furnace, it would be on top of the furnace.
Old 11-17-2013, 04:53 PM   #5
BCS
so not in the furnace near the burners, etc., blower, etc. But physically on the outside towards the top?
Old 11-17-2013, 04:57 PM   #6
An old Tradesmen
Yes, sitting on top of the furnace. Look for teh 2 copper lines that come from the outdoor unit. they run directly to the indoor A/C coil.
Old 11-17-2013, 05:41 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
Does the blower run with a call for heat?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-17-2013, 06:13 PM   #8
BCS
Yes it does
Old 11-17-2013, 07:14 PM   #9
BCS
This is what I am seeing
Trane XE 80 High Temp Limit Switch-image-3578537173.jpg   Trane XE 80 High Temp Limit Switch-image-2880431263.jpg
Old 11-18-2013, 07:48 AM   #10
BCS
I realized that I might of missed the actual furnace filters. However, I've looked everywhere and can not see where it would be located.
My furnace is up in the attic and the only filters I changed were the 3 in the ducts by the ceiling underneath.
Should there be filters right next to the furnace? I dont ever recall changing those or the HVAC guy that came to service the furnace, AC, etc. He always changed the filters in the ceiling.
Is it possible that the furnace doesnt have a filter in the attic and due to the duct work, they are located in the ceiling for easy access and replacement?
Old 11-18-2013, 07:58 AM   #11
BCS
Here's a picture of the set up.
When looking at the furnace straight on. This unit is to the left (next to the burners) and there is a lot of air that comes out of the top right hole in the picture. Could the filter be in there?
Trane XE 80 High Temp Limit Switch-image-1195486332.jpg   Trane XE 80 High Temp Limit Switch-image-3952511860.jpg   Trane XE 80 High Temp Limit Switch-image-495167883.jpg
Old 11-18-2013, 11:22 AM   #12
biggles's Avatar
trace the pair of wires from the hi limit switch remove from board and read the switch again thru the wires going into the hi limit switch O.OO is closed like having the two probes touching.jump the hi limit at the circuit board terminals and repower furnace and call for heat
Old 11-18-2013, 12:03 PM   #13
BCS
sorry, but what do you mean by this?
I understand to pull the limit switch out and use the existing wires going to the leads to get the reading on the multimeter, but from there, how do I jump the hi limit at the circuit board terminals?
Old 11-18-2013, 04:01 PM   #14
An old Tradesmen
The front panel where those copper lines are comes off. Its a few screws. Then you can access the coil plate behind it, an remove the plate and look to see if the coil is dirty.
Old 11-19-2013, 10:53 PM   #15
BCS
Coil plate was clean. I suspect its the board by now As the high temp limit switch is not open .
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 06:21 PM
Trane Open High Limit Device mdcheddarhead HVAC 3 03-02-2008 05:43 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 11:33 AM
