Trane XE-80 - Furnace No Start - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 10:16 AM   #1
Exclamation
Greetings,
My furnace does not start and the cold weather is coming in. When the thermostat is set for heat to come on, the furnace hums, but the blower does not start. The squirrel cage can be rotated easily by hand. Error code show one long, one short, pause, endless blinking about a second apart.
The unit was installed in 1994 and has never had service or anything go wrong in all the years of faithful service.
Any help would be greatly appreciated, and thank you in advance.
Dirkasaurus-rex is offline   Reply With Quote
Old 10-25-2010, 01:25 PM   #2
HVAC / Plumbing
Are you talking about the exhaust blower won't start ? look on the back panel to see what the code is
kenmac is offline   Reply With Quote
Old 10-25-2010, 03:23 PM   #3
OK, I'm a bonehead. Advice to others seeking resolution, make sure your thermostat has a charged battery and that the heat-off-A/C switch is not set to off.
I switched mine to heat, turned it up, and presto-chango the furnace is now working... Thanks!
Tags
blower fan , error codes
Help TRANE XE-80 furnace squeed HVAC 14 01-01-2015 12:29 AM
Oil Furnace Won't start ScottEW HVAC 0 10-05-2010 09:26 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Trane xl-90 2 stage furnace problems ikon07 HVAC 5 03-14-2008 09:14 AM
Cozy Propane Furnace Start up Noise NJ Gimo HVAC 7 01-01-2007 11:06 AM
