Trane XE 80 Control Board Fuse Blows - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 01:10 PM   #16
Hey I understand, I have been repairing this furnace off and on for 10yrs now but this one has me stumped.
Thanks for all your help.
ShotgunW is offline   Reply With Quote
Old 12-04-2010, 01:57 PM   #17
hey Guys, Can rollout switches , limit switches etc be tetsed without the furnace operating? Should I touch ohm meter to each side of the terminals and what readings should I get???
Old 12-04-2010, 02:07 PM   #18
AKA HVACTECHFW
Rewards Points: 1,208
yes, set your meter to ohms, remove wires from switch and check for continuity between terminals, or for your case you check between terminal and ground
hvactech126 is offline   Reply With Quote
Old 05-12-2014, 01:19 PM   #19
Trane XR80 Control board 5 amp blowing
For me it was go outside. Remove cover where wires go into outside AC unit. Found bird nest and two wires which were bare from bird tugging on wires? Cut out old wire and used wire nuts to splice in new wire. Now COOL again Good luck ... 5 amp controls 24Vac ohmed out transformer and 24vac side was 2 ohms which is ok as I found out later looking at bare wires near bird nest
kaplaa is offline   Reply With Quote
Old 05-12-2014, 04:11 PM   #20
Rewards Points: 582
Iam sure after 2yrs he has it fixedposte d 2010
The Following User Says Thank You to ben's plumbing For This Useful Post:
hvactech126 (05-12-2014)
Whirlpool refrig. problem ken1415 Appliances 147 02-25-2017 12:27 PM
Goodman furnace control board patz83 HVAC 7 03-14-2010 02:07 PM
York gas heater control board replacement spyvan HVAC 5 12-29-2008 07:12 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
