Trane XE 80 Burn My 120 To 24V Transformer - HVAC - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 03:45 PM   #1
Trane XE 80 burn my 120 to 24V transformer
Yesterday I came home and found that my indoor unit burn the transformer. I installed a replacement but the A/C wouldn't work. After a few minutes I noticed a burn smell coming from the unit, I immediately unplug the unit. Today I went ahead and tested the transformer with everything off. It was giving around 26 volts. I went ahead and fused the secondary side with a 1.5 amp fuse. When turning on the fan alone it works fine. When positioning the thermostat in heat or cool, I blew up the fuse right away. I took off the fuse and repeated the process using the door switch so I could get the power off in a hurry, I get a small buzz sound from the transformer and the voltage reading drops to around 8 to 9 volts. At the same time the transformer starts getting hot. I check the outside unit (heat pump) contactor winding and is not open. Any suggestion will be appreciated. I also bougth a new transformer but not using it since the first one tested good without major load on it.
berr3555 is offline   Reply With Quote
Old 05-19-2011, 04:59 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
most likely it is the contactor or chewed through and shorted to ground wire
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
berr3555 (05-19-2011)
Old 05-19-2011, 06:32 PM   #3
I went ahead and crawl all over the attic and the wiring is fine. I took to the outside unit and exchange my contactor and it is finally working. hvactech126, thank you for your expert advice.
Old 05-19-2011, 11:58 PM   #4
HVAC Tech
Ducthunter's Avatar
So why did the fuse blow when he was using heat if the short was in the y circuit?
Ducthunter is offline   Reply With Quote
Old 05-20-2011, 07:06 AM   #5
AKA HVACTECHFW
most likely because it is a HP instead of ac
IT IS WHAT IT IS
Old 05-20-2011, 07:52 PM   #6
HVAC Tech
Ducthunter's Avatar
If it's dual fuel I guess the xe 80 is a 80% gas furnace, single stage I think
Old 09-28-2012, 09:23 AM   #7
The contactor
I forgot to update, the problem was the main contactor in the heat pump had a short in the winding side.
The Following User Says Thank You to berr3555 For This Useful Post:
bob22 (09-28-2012)
Trane X1000 120/24VAC Transformer Slim2011 HVAC 20 01-31-2011 08:27 PM
transformer failure in a Trane XE78 turtleescape HVAC 7 07-19-2010 08:34 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 10:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 12:10 PM
