Trane XE 80 Blower Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2007, 09:54 PM   #1
Trane XE 80 Blower not working
I have a Trane XE 80. The outside unit will run but the blower motor inside will not turn on. The indicator light is not in either. Any suggestions?
SKey is offline   Reply With Quote
Old 06-24-2007, 12:27 AM   #2
Rewards Points: 1,088
Blower will need to be replaced. Same thing happened to me, but during the heating season. Luckily mine came with a 5 year all parts and labor warranty. Haven't had a problem since.
handy man88 is offline   Reply With Quote
Old 06-25-2007, 08:10 PM   #3
I had the same problem with this unit. I needed to have mine replaced also. You could check the safety switch. If you look on the outside of the blower housing there is a small circular switch that is screwed onto the sheet metal.
There are wires that connect to both sides of that switch. If either is disconnected, the blower won't operate.
But more than likely, the motor is shot.
-S
squeed is offline   Reply With Quote
Old 06-25-2007, 08:24 PM   #4
Union HVAC Tech.
If the safety switch wasn't made then the transformer wouldn't have power to bring on the outdoor unit. If the idiot light on the board isn't on I would check the connections to the board, the line power to the transformer is connected ahead of the other circuitry on the board.
bigMikeB is offline   Reply With Quote
Help TRANE XE-80 furnace squeed HVAC 14 01-01-2015 12:29 AM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Induction blower seal ktritz HVAC 4 03-05-2007 09:52 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
trane furnace with inducer blower error tjh57 HVAC 1 10-22-2006 08:45 PM
