-   -   Trane XE 80 Blower not working (http://www.diychatroom.com/f17/trane-xe-80-blower-not-working-9371/)
SKey 06-23-2007 08:54 PM
I have a Trane XE 80. The outside unit will run but the blower motor inside will not turn on. The indicator light is not in either. Any suggestions?
handy man88 06-23-2007 11:27 PM
Blower will need to be replaced. Same thing happened to me, but during the heating season. Luckily mine came with a 5 year all parts and labor warranty. Haven't had a problem since.
squeed 06-25-2007 07:10 PM
I had the same problem with this unit. I needed to have mine replaced also. You could check the safety switch. If you look on the outside of the blower housing there is a small circular switch that is screwed onto the sheet metal.
There are wires that connect to both sides of that switch. If either is disconnected, the blower won't operate.
But more than likely, the motor is shot.
-S
bigMikeB 06-25-2007 07:24 PM
If the safety switch wasn't made then the transformer wouldn't have power to bring on the outdoor unit. If the idiot light on the board isn't on I would check the connections to the board, the line power to the transformer is connected ahead of the other circuitry on the board.
