Trane XE 80 4 Flashes On Board - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 08:47 PM   #1
Trane XE 80 4 flashes on board
Hi
I have a Trane XE80 that I'm trying to fix. LED on the control board flashes 4 times indicating a Hi Limit switch open. Where is the hi limit switch? I've metered all of the sensors that I could find and nothing shows open. Does anyone have a part number for the switch? Blower comes on but I don't see any ignighter glow.
Many thanks...
Trane Spotter is offline   Reply With Quote
Old 11-13-2008, 08:58 PM   #2
theres usually a couple of limits if its an upflow theres one on the bulkhead wall looks like a flat piece of fiberglass with 2 wires on spadeclips coming out of it might also be one in the blower compartment and possibly one on each side of the burners these are more like a silver discagain with the 2 wires. look on the wireing diagram there usually all wired in series so you can read them all out at once once you figure out where they are and what color wires there using
kennzz05 is offline   Reply With Quote
Tags
trane xe 80 help please
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 08:43 PM
Trane 80xl, 3 flashes error light - draft pressure problem, help? Xsta HVAC 1 10-14-2007 09:20 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
