Trane XE-78 Furnance Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 05:56 PM   #1
Trane XE-78 Furnance problem
I have a Trance XE-78 and recently it has an intermittent heating problem. When I turn on the heater it will try to ignite with the glow igniter but then the gas does not flow to ignite. It will then go to the cool down cycle and will run until I shut it off. Sometimes it ignites and runs fine. I have had an HVAC guy check it and everything seemed to work OK. He thought it might be the housing doors not secured. He came out twice and it worked when he came but stopped the next day. He also suggested to change the wall thermostat as it was 20 yrs old. The mother board will flash twice indicating the gas flow issue bit other times it works fine. I changed the thermostat. It worked fine but did not cure the problem. Today I decided to run the AC unit to check it's operation since I haven't run it for 3 months. It did not work at all nor does the heater work at all either. I checked the brackers in the panel and the Duplex plug that the unit is plugged into and they checked out fine. Now there is no red light on the mother board control unit. Thanks for any ones help.
Ona4day is offline   Reply With Quote
Old 01-19-2012, 07:18 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
You need a meter.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-20-2012, 12:00 AM   #3
I wonder if its old enough to have the old fenwall ignition control on it..............if so i would look at a new furnace before i would sink any money into that old relic.
harleyrider is offline   Reply With Quote
Trane XL1200 - Outdoor Unit Problem snifred81 HVAC 5 08-07-2012 01:53 PM
Payne Furnance PG9MAA problem peng teo HVAC 34 01-14-2012 03:13 AM
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 05:20 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
