Trane XE 78 Blower Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 11:12 AM   #1
Trane XE 78 blower replacement
My unit is starting to make some noise, and it feels like the squirrel cage has excessive play. It's not obvious to me just how this assembly is most easily removed from the furnace. Does anyone have any experience with this?
ramjet is offline   Reply With Quote
Old 03-22-2009, 11:20 AM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Look at the blower as where it mounts and there will be slide rails. Follow the slides and you should find a could of screws to remove and after you remove the screws it will just slide out. You may have to work around the wires
Old 03-22-2009, 11:38 AM   #3
Trane XE 78 blower
Thanks for the quicke response! I guess this means that the electrical control box in front of it has to come out first.
Old 03-22-2009, 02:02 PM   #4
HVAC / Plumbing
I have seen the set screws work loose on motor shafts.. Check the flat spot on the motor shaft & see if the set screw is tight against the flat spot
kenmac is offline   Reply With Quote
Old 03-22-2009, 03:05 PM   #5
I'll do that- thanks.
Old 03-22-2009, 03:12 PM   #6
An old Tradesmen
Rewards Points: 6,852
And if its already worn a groove around the whole shaft, its too late.
Old 03-22-2009, 03:15 PM   #7
Understood. It wouldn't be the first time I was too late!
Old 03-22-2009, 08:18 PM   #8
Too Late
Yea it was too late when I had my third kid if you know what I mean.
SULTINI is offline   Reply With Quote
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
Replacement impeller and clip for Heil exhaust inducer blower iixeb HVAC 2 01-09-2009 08:36 PM
Trane xv80 furnace blower not working jim2138 HVAC 2 03-22-2008 04:55 PM
Trane xl90 Combustion blower Issues bjpaff HVAC 3 12-18-2007 10:00 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
