Trane Xe 1200 Reverse Solenoid Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 07:07 AM   #1
Trane xe 1200 Reverse solenoid valve
I have a 2000 trane xe 1200 and the reverse solenoid valve is shorting out. Any recomendations on where to get a new one around the DFW area? Do I have to replace the entire valve or just the solenoid? How hard of a job is this?
Thanks,
Rickey
rick208 is offline   Reply With Quote
Old 07-14-2009, 10:00 AM   #2
Rewards Points: 260
Are you referring to the reversing valve solenoid coil? No, you do not have to replace the reversing valve, and it is a very easy job. You should be able to get one and a local supply shop (Johnstone, Bakers, etc.).
bluefitness is offline   Reply With Quote
Old 07-14-2009, 10:47 AM   #3
Yes, the coil. I found one for 64.90. I hope that is a fair price. I am glad to hear that it is a fairly easy job. I was looking at it yesterday and it look like it should be easy enough. It looked like I take the 2 wires off, pull the pin out, and it should come right off. The part should be here today.
Old 07-14-2009, 03:06 PM   #4
Rewards Points: 260
That pretty much sums it up.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
thermostat controlled Solenoid valve ? ksauerwald Electrical 25 02-06-2009 04:55 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Gas valve solenoid Yoyizit HVAC 0 12-21-2008 06:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
