Trane Xe 1200 - HVAC - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 04:49 PM   #1
Trane xe 1200
Hello new to this form, so if posted in wrong place please delete or move it .thanks
I have a Trane xe1200 an the fan outside stops working after it cycles a few times , the fan will not come back on . I have no idea how to ck the capacitor or the fan motor or contact switch any help would be appreciated .
Kikitxus is offline   Reply With Quote
Old 04-10-2013, 05:00 PM   #2
Does the motor get hot when it shuts down?
JScotty is offline   Reply With Quote
Old 04-10-2013, 10:01 PM   #3
Well it's hot up on the roof, but it seams like there is a lot heat coming from the unit . What temp is to hot for the motor ? An ill ck it when the days get hotter
Old 04-11-2013, 10:30 AM   #4
If the motor is hot to the touch when it shuts down that will tell you if the motor overheated & shut down or if a switch somewhere isn't turning the fan on. Don't know an exact temperature, but if it's too hot to hold your hand on for more that a few seconds it's probably overheated which would lead me to the problem likely being the motor itself or the capacitor.
The capacitor is pretty cheap so that would be your best bet, if that doesn't fix it. If the motor isn't any hotter than the metal case for the unit then more than likely a switch somewhere isn't sending power to the motor.
Old 04-11-2013, 12:02 PM   #5
Thank You Sir ! I will ck the motor .
Again thank You
Old 04-12-2013, 05:59 PM   #6
Again thank You
Ok , the fan did not work when I first turned it on this afternoon .
I noticed it look like it wanted to spin so I taped on the motor and it started
To work . So I'm guessing its the motor ? Or could it still be the capacitor ?
Thanks .
Old 04-12-2013, 11:22 PM   #7
REP
Sounds like the capsitor to me.That is only a 10-12 dollar cost so change that out and you should be good to go.If that don't do it then its most likely the motor and you always change the cap when you change the motor so you'll need it anyway.
REP is offline   Reply With Quote
Trane Xl 1200 5 ton Compressor Fan replacement opions needed spg112357 HVAC 35 01-04-2012 03:08 PM
trane xe 1200 capacitor question sippnwhiskey HVAC 6 07-19-2011 10:07 PM
Trane XE 1200 Stuart24 HVAC 2 06-30-2011 02:09 PM
2.5 ton Trane XL 1200 ain't keep'en up with the cold DIY DUDE HVAC 14 01-15-2011 02:55 PM
Trane xe 1200 Reverse solenoid valve rick208 HVAC 3 07-14-2009 03:06 PM
