Trane XE 1100 No Heat Only AC Works. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 10:51 PM   #1
Trane XE 1100 no heat only AC works.
I have a Trane XE 1100 The compressor and fan outside will not come on in heat mode but will in AC mode. Does anyone know what I could try. I replaced the thermostat and it didn't work.
aderhojl is offline   Reply With Quote
Old 02-12-2012, 07:46 AM   #2
biggles's Avatar
check for a transformer out within the condenser
Old 02-12-2012, 09:53 AM   #3
HVAC Tech/ Browns Fan
It can be a lot of then's. It can be t stat, outdoor control defrost board, low pressure switch or It can just be too cold and h.p lock out due to low temp outside
Tator1076 is offline   Reply With Quote
Old 02-12-2012, 11:58 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
If it works in a/c mode and not heating, then you need to verify you are getting the proper signal outside in heating mode. Check for 24V between Y and C at the outdoor unit with a call for heat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-12-2012, 12:42 PM   #5
thermal-medics.com
Service lately
Just curious: Split system or package heat pump (all on roof)? When you ask for heat at the T-stat (new or old) did the blower motor operate (air from vents)? Did you have the unit serviced lately? Did it run in heat mode up until now with no problems? Did you run it in heat mode during a warm day? It is 78 in Phoenix today.. we desert rats are whimpy..
Keeping it simple, does the defrost control board (circuit board inside outdoor unit have a blinking light you can code match to the manual)?
thermal-medics is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Trane TCONT803 Tstat install ... on Trane XB14 system chaaalie HVAC 10 09-08-2011 07:56 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Pressure Switch Stuck Closed --heat works but A/C doesnt assassinmunky HVAC 0 06-23-2009 03:49 PM
