Trane XE 1000 (TWR060C100A2) Repair - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 06:55 PM   #1
Trane XE 1000 (TWR060C100A2) repair
I have a Trane Xe 1000 that is 14 y.o. Had a service technician evaluate the unit and of course he came up with a laundry list of work he says the unit needs. The list reads: 1) replace 15 uf capacitor, clean interior cabinet, replace 24 v 30 amp contacts, install a 12 x 12 return grill, and add a new compressor saver kit. He recommend the return grill because I told him my son's up stairs bed room gets very warm, even with the AC on.
He also says that the condenser unit should be removed from the covered patio area, which is not enclosed, to a concrete surface on the ground.
This is a 5 ton unit that still works. I am a handy man with knowledge of capacitors, and some electrical knowledge, and would like to do the work myself. Will these recommended repairs make the AC more efficient, and solve my upstairs cooling problem? I don't believe the unit need to be replace at this time.
wterlwms is offline   Reply With Quote
Old 09-27-2010, 08:07 PM   #2
HVAC / Plumbing
Wouldn't hurt to have a hard start kit. Don't know about contractor .. May have have burnt contacts. If the condenser installed where there is restricted air flow/ movement, it may need to be moved. A return will remove hot air from the room,, In the old days, Every room in the house had a return
kenmac is offline   Reply With Quote
Old 09-27-2010, 10:46 PM   #3
Thanks! What is a hard start kit, and is it something a handyman can install? Also, the contacts are a little burnt. Will replacing them may the AC more efficient?
Old 09-27-2010, 10:58 PM   #4
HVAC / Plumbing
Depends on how handy u are. Just google hard start kit.Comes with instructions..Just gives a little xtra kick for starting the compressor. If the contacts are burnt bad enough it may not get the correct current / voltage to the compressor or keep the compressor from comming on all together compressor, The only way to make efficient is to install a higher efficient mod.
Trane XE 1000 jumper reversing relay raff98 HVAC 5 07-25-2010 04:34 PM
trane xe 1000 fan not running redstepchild77 HVAC 1 06-18-2010 01:37 PM
Noisy Trane XE 1000 outdoor compressor CZ DIY HVAC 25 02-14-2010 08:46 AM
Trane XL 1000 Compressor fan motor wiesph HVAC 5 09-12-2009 05:53 PM
Trane XE 1000 Fan Problem Flathead64 HVAC 15 07-01-2009 10:08 PM
